I had to use a pair of spindle bearing adaptors cos my mid 72 disc spindles are identical to drum spindles.
Ed contacted the vendors in the States for me (ta mate
 ) and they got over here for about 50 quid.
 ) and they got over here for about 50 quid.Installed new inner and outer bearings, along with new grease seals.
If you look in the pic of the 2 discs side by side from the underside you can see that the boss around the rear bearing is much more obtrusive than the stock piece.
This did cause some problems cos I couldn't understand why the new rotor wouldn't seat against the bearing surfaces, and when I wound the bearing adjuster nut in a little it jammed the rotor.
I whipped off the dust shield from the hub cos it looked like it could've been interfering with the back of the rotor hub and it fitted perfect, so I ground a quarter of an inch off the shield, you can see it modified in the pic along with the bearing adaptor on the spindle.
Managed to obtain a set of EBC Yellowstuff carbon ceramic fast road/trackday pads, along with the high carbon steel content of the rotors and the slots and grooves allowing the heat and gasses to dissipate, these should give a good improvement over the cheapo 2 piece rotors that don't do a very good job of stopping my car, can nearly stop my heart tho
 by Adrian Worman » 12 Feb 2014 21:08
