				Ground and tachometer
22 Jul 2013 20:48by Apewalski70
				Hello !
Two questions, when lights is on turn signal are not good and if I push brake pedal the lights are low, bad ground you think ?
My tachometer work but he is connect to the positive terminal of the coil, (on negative he doesnt work) bad coil ?
 Thanks you.
				Re: Ground and tachometer
23 Jul 2013 8:42by Adrian Worman
				Yes, poor ground on the tail light issue, the fault could be just with the grounds from the rear light clusters .
If cleaning and making good the ground doesn't help or only helps a little bit then you have a poor ground somewhere in the entire lighting circuit, so check headlight grounds, sidelights, even the light switch itself.
The tach is fairly easy, if the coil was bad the car won't run so you can eliminate
Check the wiring loom carefully, I'd suggest checking out the wiring schematics at the top of this section.
23 Jul 2013 10:40by Apewalski70
				Okay thank you Adrian I will check that
23 Jul 2013 11:03by Adrian Worman
				Forgot to ask, factory or aftermarket tach?........ positive side is right anyway
23 Jul 2013 11:53by Apewalski70
				Aftermaker from Yearone, I ask to Yearone they said me that :
"If the tachometer works with the gray wire connected to the coil positive terminal it indicates the coil is defective (reversed coil polarity) or the ignition is wired incorrectly (wires attached to the incorrect terminals)."
Positive side send me the good information ?
23 Jul 2013 12:24by Adrian Worman
				Oh, sorry, my mistake I typed that in completely wrong
 ................the grey wire should go to the NEG side of the coil.
Are you certain the power feed is connected to the back of the tach itself?
23 Jul 2013 12:32by Apewalski70
				Yes the 2 wires is connected to the back, I changed all the harnesses some years ago so all wires are in good condition, harnesses are from Yearone, I connected all harnesses with the schema so they are in good position.
