I've noticed that the lamp located over the AC controls stays on, regardless of whether the parking/ headlamps are switched on. Is this normal or do I have this plugged into the wrong plug somewhere? Thanks
Re: AC Control Light Bulb Stays On
Posted: 03 Dec 2012 21:26
by walkAbout
Do you mean the lamp that is located in the switch panel and shines down tru a hole to the A/C controls? The are pictures here in this forum. The yellow wire goes to an orange terminal and is operated with the light switch, means it is only on, when the parking/ headlamps are switched on.
CU walkAbout
Posted: 03 Dec 2012 21:36
by cv70chall
Yes, that sounds like it. Where are those pictured?
In the first 3 pics you see the lamp with the short yellow cable going into the orange wired connector.
1 OT question: Did you get a notice/mail about my post? I can't find any notification in this board.
CU walkAbout
Posted: 04 Dec 2012 12:59
by cv70chall
LOL If you're talking about the yellow wire thats plugged into the orange wire- then I'm good- but still have an issue. If it's the single yellow wire (scroll down) with a round plug at the end- this might be the one you are talking about- and I don't know where it goes.. ??
Posted: 04 Dec 2012 21:36
by walkAbout
Yes, I mean the yellow/orange wires are plugged in the way they should.
The yellow wire(s) with a round plug at the end are open on my Challenger too. I'm just starting to add more parts of the A01 package, so I have to find out, what they are for. Maybe for the ignition key light. Oh, again, in your other thread ^^ it is answered as: for the key light, what means ignition key light. See pic 2947751.jpg in the other thread. That's the light. I miss it so far...
