Well took the my challenger out of winter storage yesterday,a nd I am having a problem with the brake lights, and I wasn't sure if anyone has had the same problem before.
Car is 1970 with 440
Brake lights start flashing and stop working all together, then start working again. I checked the pedal switch it has power to it, and it sends power to the other side once it is activated. The white wire which connects to the brake switch is reading negative when disconnected?? My best guess is the turn signal switch is shorting?? What do you guys think? I changed this swtich 4 years ago with a part from year one and I havn't had any problems with it prior. Is this common?
Thanks Matt
