Adrian Worman wrote:I've got Dons stuff in my Chally now, it's fitted to a stock dist tho with an advance plate. I got a Mopar Perf unit in that bunch of parts for the stroker motor, along with an MP drive gear and I thought I'd make use of it but only if it was actually any better quality than the factory piece.......
I suppose it's worth using cos its new and ought to give more reliable and consistent performance, maybe the vac can is a little better
Well the 'drive gear' should be pinned, the stock was a press fit only,, so the MP unit is better! If it were mine,, I would use the MP distributor,, with a lot of initial, probably at least 20 depending on your cam of course, then Don's or aftermarket ECM NOT the MP one. They supposedly drop the dwell,(coil saturation time), after 4,000 or so RPM's ,,, this will change the timing,(Retard it). Don's ECM's reportedly dont do that. Regardless, I would use a MSD-6 capacitor style ECM with a Blaster-II Coil if your budget allows if not use Don's ECM. This should be a good strong ignition. If you do use a MP dist. I would also get a cheap shaft collar. Dave did this and reported his timing improved considerably. I am gonna do this too when it's in the car,,, someday
