 by cv70chall » 02 Apr 2012 12:47
			I'm still having horn issues, although they are different.
I took apart the top portion of the column- after isolating the grounding to an area between the main molex plug and the top of the horn ring.
After taking apart the crush can, I noticed that the rim of insulation under the brass contact ring was completely gone, so I replaced that with a nice large grommet.
After reassembling the can and making sure there were no kinks/ bare areas in the wire, I tried the horn and it seemed to work fine.
Only problem was - that it grounded again, but this time, when you turned the wheel or pushed down on the wheel itself, leading me to believe that it's now grounding somewhere at the point where the can and column meet.
What is usually in place there to prevent this and what can I do to remedy it?
Thanks
CVchall70
