Light Bat Lamps Flashing with Turn Signals...
Can anyone sort this one out? Could this be a poo ground issue? I'm positive everything plugged in where it was supposed to. Could it possibly be a bad flasher?
I'm also still trying to clear up 3 more things:
1. The single yellow wire coming out of the steering column. I do not see a key lamp assembly (I just bought one to install however) and was under the impression this wire was for that. ????
2. The single yellow wire with a black tracer. ????
3. The plug coming off the main harness with a PINK AND RED WIRE AND TWO BLACK WIRES WITH YELLOW TRACES. This is located near where the flasher is supposed to be, but it's already up there and plugged in. ????
Lastly, does anyone have a picture of the MAP LIGHT ASSEMBLY?
THANKS THANKS!!!
THANKS THANKS!!!
