Yeah, that's the one, Mopar specific 12 circuit wiring kit .
You'll need a small amount of extra wire to provide but only for a couple of jobs and only a few feet, any regular parts counter will have it.
I crimped some conns and soldered some others, all depended on the connection, but remember you will only be making the end conns, the fuse box is already wired for you.
Allow yourself one clear weekend and remove the dash and the seats, it sounds a bit extreme but it made the job so much easier for me.
While your at it, do the electronic reg mod to the back of the instrument cluster, change the ballast resistor wiring to the single feed system and install a new electronic volt reg of the highest quality and make sure everything is earthed properly.
I also changed the crap Mopar starter relay for a much more robust Ford unit, same wiring tho.
I know it seems like extra work but I can jump in my 72 and drive it anywhere with confidence, greedy 440 allowing of course
Good luck mate, one of the most effective mods you can make to a Mopar
