Please can someone give me some pointers as to why this might have happened?
 The turn signals kept blowing the fuse which then burnt out the turn signal/hazzard switch in the steering column, I have since replaced this and both the 4 way Hazzard & 3 lamp turn signal relays but still no turn signals, everything else, front/tail lights, brake & Hazzard lights all flash fine. All fuses are fine.
Hopefully this is a common problem that someone might know the cause?
Cheers
 by colchester1978 » 22 Jun 2011 10:57
