1970 Loss of Turn Signals, Help please
Hi
Please can someone give me some pointers as to why this might have happened?
The turn signals kept blowing the fuse which then burnt out the turn signal/hazzard switch in the steering column, I have since replaced this and both the 4 way Hazzard & 3 lamp turn signal relays but still no turn signals, everything else, front/tail lights, brake & Hazzard lights all flash fine. All fuses are fine.
Hopefully this is a common problem that someone might know the cause?
Cheers
Cheers
