I posted this question on the site before so appologize for asking again.  I've been struggling with this issue for 5 months and seem to be getting nowhere.  Here it is.......I have two ballast resistors in my engine bay, a four post and a two post.  The four post is wired correctly but the two post is missing one of the wires.  Before I broke the car down for restoration I took pictures of everything and it looks like one of the wires comes off the positive side of the coil and runs to the left side of the two post resistor.  However, I can't locate where the right side of the ballast resistor wire comes from (right if the bolt holding to the resistor to the fire wall is on top of the resistor) because it was obstructed when I snaped the picture.  Could it be possible that the right wire comes off the negative side of the coil?
I've looked at wiring diagrams for months and just cant figure it out.  Actually, every diagram I've seen only shows one ballast resistor in the engine bay, the four post.  It's possible the two post was added aftermarket.
If anyone can help it really would put an end to this never ending frustration.
 Thanks!
