I don't think I've ever had the correct adjusting arm,head mounting bolt or even water pump pulley
dave-r wrote:That is the later mid-70s version I think. Wouldn't be fitted to Challengers like that.
dave-r wrote:What year Barracuda? Numbers matching?
I had factory AC and PS on my 440 when I got it. The brackets are similar to the ones I posted above but not the same and spaced differently (further out from the block) with a more shallow water pump pulley. No idler pulley for sure. I can't remember when they started fitting those. Not 1970-71 I thought?
dave-r wrote:Then again. Maybe mine was missing and the idler should have been there? It is in the factory manual even in 1970.I probably have that wrong then.
I can't remember how mine was belted now after all these years. I do remember that the alternator tensioned one belt and the PS tensioned the other.
