Jeez these Mop,s are more fun than a barrell full of drunk monkeys.
After sorting out the ballast & tacho problem I took the car for a run yesterday only for it to cut out miles from nowhere.
No power at ignition switch, no cranking, zippo.
After checking all the usual suspects I found a wee brass element on the drivers floor, 1/4 spade one end & 1/2 moon loop the other end.
On checking some other posts in the electrical end of the forum I see 2 of these boyo,s in the photo shown, as part of the switch set up.
Would any member know.
What is their function
Can they be refit without stripping out the column similar to the changing the ign barrell thread.
To get home I ran a wire from the + coil to the + battery and cranked via the fender solonoid connections.
Not sure if this is method is recommended but it done the trick.
