 by drewcrane » 23 Jan 2010 4:10
			ya know i myself had had some fire/ground issues in the s.column,and from the pix, i cant see alot ,but from what you say(soldering/wires that go no where) you need to look at your factory wiring diagram,
 if you dont have that,  i have one right here, also if you can take a better pic so i can see the wire better the pinkish wire is it actually violet?
because the 3 wires on my diagram for the horn are dark green,violet, and black
,now this may not mean anything because i  have changed my wires, but get a better pic , or description of the color
 or a good look at the color of the wire, and  post it here, also just hook up the battery and see if the horn works,
Am I assuming correctly that this wire should be soldered to the ring?
yes that is the horn ring and a wire needs to be attached for the horn to work,
 this all needs to have a good ground
