While finishing up the underside of the trunk area, and after replacing the gas tank, sending unit, etc. I see a wire hanging from the frame. It appears to be in the bolt hole area for the heat shield. I asked a local guy about a ground wire there and he doesn't think it was there originally. Is there supposed to be a ground wire in that area, and if so, where does it attach to?
Paul
