i swapped my wifes gc barracuda, it came with a standard dash and it was not that hard some of the wires are still in the harness ,i had to add the tac wire,i think the wire for the oil pressure is the same for the oil light,and you will need power for the clock ,which there are some accessory feeds, with 3 power out lets, i think the block is pink or orange,speedo is the same ,and the amp gauge is the same also,
its not that hard once you get under there i wouldnt swap out the harness it would be more work and something might happen using an old used one
 give it a try if you need help post it here,
just a side note i scanned the 2 pages in the factory manuel with the wiring schematic/diagram and the laminated the paper so then all i have is the diagram/schematic to hold on to instead of the whole manuel,you wont have to flip through pages its right there easy, handy,
 if you have a scanner or a copier,i have seen these for sale but i just made my own,i have also seen poster sizes and the are sweet cause everything is much easier to read but this will work with some reading specticals
i have the engine diagram on one side, and the interior on the other side
