i know those screws might have grounded it , but do know that there is a ground strap in the dash frame and it is on the left hand side of the lower part of the dash, below the heater controls,it actually holds a part of the trim,and goes through the ground strip, and and the to the dash frame it is a long screw, it grounds alot of stuff, but try grounding it first with a wire and see what happens.Rizrtse wrote:ok, will try to ground the bezel but isnt the cluster normally grounded bu the 6 screws that attach it to the dash frame? What ground screw are you suggesting? Also, radio is dead along with wipers as I stated above. Oh Dave where are you?
Steve
Rizrtse wrote:Oh Dave where are you?
Steve
Rizrtse wrote:ok will do. What aboutthis circuit breaker thing I see in the wiring diagrams
.gif) that's it. Not an intermittent event so that may not be your "current" problem. Actually the fuse is a fail safe for another problem in the circuit(s). Only one i know of outside the fuse block is the fusible link in the engine compartment. But that would kill everything.
Jon wrote:
I would go to the bulkhead and clean all of the connections then check the wires going to your malfunctioning components with a multimeter or continuity light. Good luck.
 Especially since it happened after it rained. This could have gotten water in it if the rain were that heavy.
 what do you think you found by the way?
