Dave, i have read through the procedures you wrote out for Setting Ign Timing.  I have a 360 with a fairly big dur cam (about 290) but i can get the car to idle reasonably happily in gear at about 650-750 RPM, so its not that big a cam. I have found that without my vacuum advance connected, i am still getting advance figures of around 45+ degrees at only around 2500rpm.  I have put the initial on about 18 degrees as you said.  My vacuum at idle (manifold vacuum) is about 10.5-11 " HG, so its not too bad.  I need that much initial timing in order to be able to reduce the carb idle speed, otherwise i get horrible stumbling on part throttle/coast due to the transfer port not working correctly (its a T Quad).
The dizzy is just the std MP electronic, with chrome ECU.  Should i have that much advance at such a low rpm with no vac advance connected? I may need to recurve the centrifugal weights, but not totally confidant in doing that, also no idea where i can get springs. It drives well with not a hint of pinging with no vac advance connected.  And that is with a 2.76 gear set, in top gear going up a hill at 3/4 throttle. I have not tried connecting the vac advance to manifold vacuum.  The resultant increase in revs from this might allow me to reduce the initial timing and therefore will bring down  the total to what it should be - 32-34 degrees?  Thanks.
		 by Goldenblack440 » 23 Jul 2009 13:29
