HI all - on a SB engine (mine is a mild 360), what should normal operating temp be reading on the rallye gauge? I have had the gauges checked over and have tested 3 sending units. It is reading very cool at normal operating temp, just barely off cold. All the small blocks i have had all seem to read low. Is this a Chrysler thing? The sending units are all different when tested. One was 900ohms cold to 85 ohms in boiling water, the other two were 250 and 180 ohms cold going to 44 and 22 ohms in boiling water. Obviously in an overheat situation it should go top zero ohms which would be full scale hot on the gauge. But i would think that normal operating temp, the gauge should read about the middle. Thanks
ByTheWay, the sending unit that was in it was the lowest ohms, so it should read the highest...
.jpg)
oh yea sorry we yanks are still in the cave man era on measuring stuff
.gif)
