by Goldenblack440 » 20 Jun 2009 11:10
Thanks you guys from Indiana! Eddie, i thought they were for the heater hoses at first as well. Bob, i appreicate the picture, that's cleared it all up. Bit of an overkill for those small wires really. Looks a bit untidy, but that's how they did it. I just routed mine around the booster, as in the picture. As you can see, my car is not conforming to original!! As i told Ed, my original master cyl, sprung a leak. Interesting how they used wrinkle black finish on the booster. Was that factory? Because i have a booster from a 70 440 Cuda which is slightly different though and that is a smooth semi-gloss black
Lastly, i have arrowed that small vacuum take-off on your booster Bob. Mine has that too. It is blocked off, do you know what they ever used it for? I have wondered that ever since i saw it there. Thanks.
![Alum master cyl.jpg (159.28 KiB) Viewed 212 times Alum master cyl.jpg](download/12118_1_Alum master cyl.jpg)
- I put my wires around the booster
![loom bracket, brake booster.JPG (117.8 KiB) Viewed 211 times loom bracket, brake booster.JPG](download/12117_1_loom bracket, brake booster.JPG)
- Vacuum take off ?
