I´ve got a big problem which I can´t figure out how to fix. I have a 318 with a Crower cam (in: 292, ,534 exh: 310, ,552) with a holley 750 vaccum carb, msd 6AL ignition, edelbrock perf intake. I have changed the holley "mouthpieces" ( don´t know if that is correct word for it ) from "68" to "63" and it run very well. But after driving for awhile it started to go bad, like it cuffed like "host host". Just like it didin´t get enough power amps. We measured the charging and it was up to 13,9V. Anyone got an idea what it might be?
 by Linka » 05 Jun 2009 19:46
 Be careful Linka,,usually the Racetrack calls for a COLDER plug heat range not a hotter plug!
 Be careful Linka,,usually the Racetrack calls for a COLDER plug heat range not a hotter plug!  You will probably have to experiement with what the engine likes as far as heat range of the sparkplugs. Good Luck  and any pics??
 Milder cam but the air/fuel (Eddie?
