Hello -
Christer, i am hoping you can help me- i think you are the electrical expert...but welcome anyone who knows this...
My 73 has the Lighting Package option. I got some of the parts in a bag when i bought the car. I cannot work out where the Courtesy Light goes. If that is what i have shown here? The bulb is sealed into a can with just a tiny opening for the light- it is more like an ash tray light, but the wire shown is very long, over one metre long. I think it lights up the footwells when the door is opened and they go off about 20 seconds later.
Also where does the Map Light go and where is the switch for the Map Light located? And what is teh Switch Title Lamp as shown in the diagram below?
The time delay relay shown is just a heat resistor wound around one terminal. As the current heats up the contact, it bends away from the other contact and opens the circuit- turning off the lights. This also powers the ignition key courtesy light.
I cannot see where this light shown in the photo would go, with such a long lead. It is not the Map Light and not the trunk light. Even the hole through the mounting bracket is not accessible with a screw driver as the light can covers it.
Anyone seen these Courtesy Lights and Map Lights? Thanks
