Hi Guys,now that i have my charging problem sorted and getting good voltage readings i have another issue with my challenger,the indicators all work as they should front and back,lights work,park lights ok,marker lights good too,my issue is my brake lights dont light up,have checked switch at pedal and all seems ok there,also notice if i put my hazzards on will light up front but not the backs,i figure they must be on the same circuit,checked connections from steering coloumn and seems ok also,any ideas as with rear indicators working a bit confused as same bulb as brakelights,could this be a fault in my steering coloumn wiring.cheers Paul
