If you replace ALL of your turn signals (front and rear) with LED lamps they may not work as they do not draw enough current for the turn relay to work.
I have experimented with tail lights and compaired LED with normal lamps. LED lamps do not come close to either being as bright OR giving an even distrubution of light behind the lens.
The BEST way to light large tail lamps like on a 1970 Challenger (for example) is to paint the reflectors WHITE and to use a normal stop/tail lamp.
Here are some photos of the tail lights on my wifes Neon. The colour is off a bit but concentrate on the brightness and distrubution of light.
LED's are much more directed light, too, so it depends on how it is reflected around the lens. Look at a plain LED light straight on and they'll blind you pretty good, but from an angle its not that intense. They're much brighter implemented in modern car lights from the beginning, rather than adapted into something designed for a bulb.
These were 22 (or more?) LED lamps with angled and reversed diodes to try to get around the lack of all-round lighting. They still do not do a good job of it. Yet they seem bright enough when you look at them. Maybe something to do with the filtering of a red brake lens?
For example. The red LED lamp did not look as bright as the white (which actually hurt my eyes looking at it) yet behind the red plastic lens it looked much darker. Suggesting there is not much in the way of the red wavelengths immitted by these things.
interesting, i have a shop light hat is led, and it too if looked at right on its is very bright, but from the side the light is almost non existant
, it seems that different colors are brighter, i have some cheap christmas lights and the blues and the purples, kinda hurt or do funny things to the eyes not that any one would use that color but it is interesting that certain colors are more intense than others:s025:
drewcrane
Yeah, the lens of the light has to be designed from the start for LED's or its just recovery mode kind of engineering trying to point LEDs in all different directions to compensate. Who knows, maybe they wouldnt be bad in a challenger taillight housing. But try a lot of them.
I'm going to give the white one's a shot. They are 31 LED's, wide angle. And will fit. I'll post some pic's. With what Dave said, I won't do all at once. Flasher has to have enough current, to do its job. I'll mix and match. I have four 1157's coming but, as you all know, I have a small car lot, of old vehicle's. I'll be able to use them in something. Thanks guy's. Patrick
