Around 1200-1400 degrees F. The hotter the better, up to the point that alluminum almost starts to melt! The back it down
 Seriously, it all depends on engine design, alloy used in the block&heads, air charge temp,compression ratio, cooling capacity, exhaust, chamber design, camshaft timing, ect.. But the hotter the combustion process the better as far as power production. The thing you have to remember is rich conditions will lower temps and lean will increase it to the point of meltdown, the 'fine line' is tricky! During pre-ignition&detonation those temps can reach 6500 degrees F. momentarily. Thats why ignition timing is very important, only use mechanical/vacum advance to the point where the engine stops making power or  trap speed. No more, over advancing on the long run causes more harm then good.
