Help please
Hi All,
I have a problem with starting the car. The problem is a couple of days a go the car would start no problem, then once at full temperature if i switch the car off then try to to restart, it was like the battery was flat. Today i started the car no problem, ran it to temperature and checked the battery with a multimeter, which read 13.6. then switched car off and nothing. All i could hear was a click, didn't crank over anything, checked battery again ok. Car now just clicks! i have also put the car into N and still nothing.
In the manual it say it could be ignition switch, or starter relay?
If anyone can help, could you explain, where exactly components are, and how to test these please! need to rectify ASAP!
Much appreciated
Daz
Much appreciated
Daz
