 by DanaProsky » 21 Aug 2008 20:41
			Well, here we go again! My 71 R/T 340 will not turn over with the key. If I jump across the relay the starter turns. This is the second new relay and they both do the same thing. I tested power at the yellow wire at the relay, when I turn the key to start, I have power (12 Volts) at the yellow wire, but the starter doesnt turn. I know I can not have 3 bad relays. I am thinking it has something to do with the brown wire on the relay, but I am not sure, if I us a jumper wire from the battery to the yellow wire at the relay, nothing. Help!
