Just got my new Rimblow wheel,(see photo), but after installing it, it dont work.
  Did some investigating, found horn relay missing from fuse box. Did all 1971 Challengers have the horn relay plug into the fuse box?  The Year One catalog says the horn relay should be under the dash by the left kick panel on 70 and 71s and it also says that 70 model relays mount to the fuse panel.???   Anyway, I got the new relay and plugged in to the fuse box, but still no horn, allthough now I here a clicking noise coming from the relay when I squeeze the rimblow, and after awhile of tracing wires and testing, I went to remove the relay and it was super hot! Damn near burned my hand getting it out! What the &%$# is going on here?
  I did test the voltage at the horns and there is none when you squeeze the rimblow, so I figure the horns are Ok, but somethings up with the fuse panel or relay. This car did have the under dash wire harness replaced a couple of years ago before I got the car, it is a M&H wire harness. Could it have the wrong one?  Any Mopar electrical engineers out there?
