dave-r wrote:Removing the dash is no big deal. It is a little tricky getting out the bolts in the windshield vents with the glass in place, particularly if they have rusted, but it is possible.
Like Dave said, removing the dash is not that hard. I did that 3 weeks ago, it took 15 minutes with a friend. I found out I didn't need to remove the scrwe in the vents (they hold the dash metal frame, all I took off was the dash pad. It has several screws you can reach from under the dash frame, and one on each side. Here's what I did :
(My seats were already removed, I'm making brackets for the race seats).
- Remove steering wheel and loosen column (removing it entirely is also a possibility - makes things even easier, but I was waiting for the new turn signal switch and starter switch to do this - probably later today.
- Remove ashtray and ashtray receiver.
- remove instrument light bar, instrument cluster, label the wires (color code is quite straightforward if you have the FSM)
- get on my back under the dash and remove the dash pad screws - I'd say between 4 and 6, I don't remember).
- remove dash pad. Easy.
- remove sill pates and kick panels (you need to do this to access the body wiring and the door switches).
Once you have the pad off, you can access all the wiring easily.
It's a big gain of time compared to the alternative : working on your back, with a lamp, with the pedals in the way, the 38-year old insulation falling in your eyes every time you move something...
