 Unless, you have dimming light's or something. When I've lost regulater's in the past, the dash light's, headlight's, all that stuff goe's BRIGHT!!! I'm talking, "Close Encounter's of the Beat Up Your Bulb's And Wiring Kind".
 And if i use turn signal, the turnsignal flash- my rpm needle drops etc..(that only in idle) OOOUuuuusssshhhhh!!!!
   I think i am going to need a complete ground check of my entire car this summer!
airfuelEddie wrote:If they are flashing correctly but 'weak' it's ground as mentioned above.
