Goldenblack440 wrote:I can't find the Horn relay on my 71. The Manual says its either on the fuse block (which mine isn't) or  "mounted in the passenger compartment, under the instrument panel at left pad".  What is LEFT PAD? Mine has AirCon- i can't find anything around there.
I believe that you have misinterpretated the service manual. Both the ´70 and the ´74 manuals (See scans below) says that the horn relay is supposed to be mounted on the fuse block.
According to the ´70 manual, the "left pad" is more correctly the "left
kick pad" (did you forget the "kick"?). I interpret that as if they are trying to describe WHERE the fuse block is located - not very far from the left kick panel (kick pad=kick panel?)
Well, this makes sence to me and I hope I am correct.
