start fit #2
Postby MLMFLCN » 12 Aug 2007 22:06
I picked up a Denso 281-0109 mini-starter at the Mopar nats this weekend. The good news is I can fit the starter in past the headers. The bad news is, the wiring connections are rubbing the block, keeping the second starter bolt from lining up (stud is fine). I took the cover off, and it seems that this piece could be removed and then just attaching the wiring from the car directly to this piece, in essence, removing and bypassing the part that was rubbing. Please see the pictures below.
Don't want to burn up my car after all this work!! Seems it should fit my 440, no? :roll:
Any thoughts are appreciated.
With the piece still attached. The black plastic part is rubbing on the side of the block, just near the first freeze plug.
MLMFLCN
Postby Eddie » 12 Aug 2007 23:48
Yes, you can discard that adapter for mini vans! I use the same starter in mine. Dont worry, it's just an extension. :thumbsup:
Postby MLMFLCN » 13 Aug 2007 1:12
Awesome :D .
Thanks Eddie. Did you make it to the Nationals this weekend?
MLMFLCN
Postby dave-r » 13 Aug 2007 7:40
I not only had to do that but I had to also shorten the stud a little on mine.
Postby Eddie » 13 Aug 2007 19:28
MLMFLCN wrote:Awesome :D .
Yeah, My brother and I spent the day there Sat. I was at the restroom most of the day. :biggrin:
Postby Eddie » 13 Aug 2007 19:29
dave-r wrote:I not only had to do that but I had to also shorten the stud a little on mine.
Yeah I get "called that" all the time. Short stud. :mrgreen:
