jh27n0b wrote:Welcome RedRaven
What wires are you touching together to get the engine to start?
Usually it is a bad ballast resistor when a mopar will run when the key is in the start position but dies as soon as the key is in the run position.
Does the engine turn over with the key or do you have to jumper accross the starter relay on the inner fender to get the engine to crank?
Bob
jh27n0b wrote:Hey RedRaven
The metal box that all of those wires bolt onto is the starter relay. I had the exact same problem with my Challenger earlier this year. My solution was to go to my local NAPA dealer and buy a new starter relay. Not %100 sure that this is your problem but it fixed mine.
Still sounds like your Ballast resister is also bad. It is the white ceramic rectangular block on the firewall right next to the wiper motor.
These are cheap and common parts to replace.
It still could be in your wiring harness or your ignition switch. Not as cheap and much harder to replace.
Can we have more detailes on your 70 baby?
Good luck and keep us posted.
Bob
dave-r wrote:Another common fault is simply a bad connection on the bulkhead connector. They are very prone to bad connections there.
So check that out before buying new parts.
There is also a connector in the wires from the steering column. So check that as well.
RedRaven wrote:so what you drivin mate??
Would you recommend year one to source parts from?
dave-r wrote:RedRaven wrote:so what you drivin mate??
http://challenger.mpoli.fi/forum/viewto ... tid=Dave-RWould you recommend year one to source parts from?
They are more expensive than the rest but are very good to deal with. I only use them for hard to find restoration parts.
There are also many good parts suppliers in the UK for normal run of the mill stuff. If you are not a member of the Mopar Muscle Association you should be as it will make your life much easier.
dave-r wrote:Ask to join the MMA message board.
It is rather like this one but is better for local parts sourcing and contacting other members near yourself. I have a feeling there are one or two other Irish members if I remember right (only a slim chance of that ever happening)
There are various traders that are MMA members too so you can get parts or even mechanical help if you need it. Sixpackspeedshop in Europe are getting very large now and their prices are very competative.
http://www.six-packspeedshop.be/ (website not finished yet)
Plus most of us all meet up at Santa Pod Raceway at the end of July every year. Just to show off and race each other.
dave-r wrote:I deleted the expletive in your message. They are a bit funny about bad language in some countries and we don't want to offend people.
dave-r wrote:Us Mopar people have to look out for each other.![]()
dave-r wrote:Did you measure your original ballast resistor to see if it was open circuit?
I bet the answer is no.
Did you test the starter relay?
I bet that is a no as well?
Fingers crossed one of those was the problem. But just chucking good money away replacing parts you have no idea are broken or not is NOT the way to find a fault. Unless you have the luck of the Irish of course.![]()
Your money would have been better spent on a volt/ohm meter and your time better spent on reading the instructions for it.
Did you ever check the bulkhead connector that the wires from the ignition switch pass through?
airfuelEddie wrote:Wayne whats the status on your electrical problem? Do you have a Volt/ohm meter yet or a simple analog meter? A test light even? You gotta get one of those man and as Dave says, learn how to use it. It's very easy and once you "get it" with simple electrical problems it becomes fun to test stuff!(not that kind of fun, not anymore).
dave-r wrote:You will get there in the end Wayne. Don't mind me pushing you. I should have been a Sgt Major in the Army.
