Jack, my instrument lights wouldn't come on and the front turn signals wouldn't work. It was a short to ground in the front headlight bucket, I thought we were going to have to take the dash apart, which was not necessary. Before you break out the DVM,(digi volt ohm meter), try unplugging the headlight wiring or wiggling the wiring to see if you can make the lights flicker, if they do you have a short to ground somewhere. A test light should show 12 volts to those accessories that arent working. Resistance would be infinite if it's an open wire. Also, make sure all your bulbs are in working order, just because it doesnt luminate doesnt mean the filament is open, it could be corrosion causing a short. I would try all the "basics" before dissassembly. Let us know!JackT wrote:A little help with this one, please...... when I turn on the headlights, my dash lights,side marker lights, taillights and front running lights do not come on. The front and rear turn signals work as do the brake lights. All the fuses are good, so where do I look to solve this problem?
