starter not disengaging when key released to run position
Hi all,
I switched to electronic ignition on my 72. Checked and rechecked the diagram provided on moparts. everything seems to be correct. I have a four prong Ballast, only using one pair.
Car will turn over in start, but when key is released, it continues to turn over.
New starter relay, new mini starter.
The ignition was removed from the column about six years ago to get a key made. I don't know how it was reassembled or if it is possible to assemble incorrectly?
Any ideas on what to look for first. Service manual has three suggestions:
starter relay
starter solenoid
ignition switch
any more?
Thanks all.
starter relay
starter solenoid
ignition switch
any more?
Thanks all.
