Removing pulley from alternator
02 Nov 2006 12:57
by GDB
Could someone tell me how you remove and reinstall the pulley from an alternator. I am assuming you use a wheel puller to remove it and do you press the new one on and if so would you use loctite on it?
02 Nov 2006 13:51
You have to use a bearing puller. They press on.
I don't have either so I cut the old one off and managed to press the new one on by putting it against a door frame and with a block of wood and a jack on its side against the other side of the frame.
02 Nov 2006 13:55
by GDB
Thanks. would you use loctite on the new one?
02 Nov 2006 16:06
I wouldn't bother. When I say press on I really mean it. They are a VERY tight fit. Maybe a ton of pressure to push it on?
02 Nov 2006 16:07
Oh and if you use a door frame like me then pick one the wife will never see. Then fill and re-paint it when she is not looking.
02 Nov 2006 19:25
by GDB
Thanks for your help. I bought my car when my wife wasn't looking.
03 Nov 2006 10:55
by ianandjess
yep they are real tight i used a 10 ton press and it still didnt want to move the pulley broke in the end & had to be replaced
cheers ian
04 Nov 2006 16:56
by GDB
G'day Ian from Canada. Thanks for the heads up. I decided I better take it to an alternator shop.
