Hi,
I've got a problem of over-charging on my friend's 1968 road runner. After a long drive, the ammeter needle hits the right corner...fully. Measurement reads 17+ volts on the battery, on idle. So, this should be the voltage regulator right? Replaced it by another one, same result after a long drive (about an hour). Besides this, my fuel gauge is not working properly. It reads more than empty (but it isn't) and during the drive, the needle rises. Does this have any connection with the overcharging problem?
Alternator is new (dual field). there seems to be a resistance in the car when the ignition is on (not running),measured between battery - and chassis. About 60 Ohm. Ignition off reads 0 Ohm.
Does anyone have a clue?
