1972 340 timing 180 degrees out Should it Run?
I have a 1934 chrysler coupe with a 1972 340 LA engine. Installed new D.U.I electronic distributor to solve a previous problem with dual points standard distributor. Engine ran, but missing and unable to find timing mark on harmonic. We are installing a new cam, so decided to investigate timing gears and found new double roller cloyes correctly installed and marks line up on TDC with cylinder 1 up. Last thought was to check distributor rotor position and found it to be 180 degrees off. I was amazed that the engine could run like this. Anyone had similar experience???? By the way, the engine did not run well and often died leaving it impossible to start.
