Rallye dash tachometer
I sent the (stock) tach from my 70 R/T to a guy here in the U.S. for repair. It had not worked since I bought the car in 1975. The problem with the repaired unit is that it will works fine, (although a little slow responding) for about 5 minutes after initial start-up then slowly stops reponding at all. If I stop the car for even a couple of minutes say to get gasoline. It will do the same thing except stops working in less time then the initial start-up.
I have sent it back to the repairman once whereas he tested it for 20 miniute and it worked fine. He suggested that there is a problem with my wiring or ignition. I have the Mopar dual point to electronic ignition conversion set-up along with a new Accel Super Coil. I changed out the ballest resistor as recommended with no change in results.
Any help would be appreciated.
Jon
Jon
