I recently had a problem with the dimmer switch on my 70 R/T. You can take the switch apart by bending the tangs and carefullly removing the retainer washer on the back of the spool. Clean the contact points and resolder any broken connections. I don't know if it is a common flaw in the design but mine had a bad ground connection to the outside casing.
Hey Dave..lol.. long time no see!
was an old member back in 01 when i first got my car... you helped me alot!
Im having the same trouble with my dimmer switch too.. Im terrible with electronics!.. just how do you by pass the switch ? having that very dim green light on all the time wouldn't bother me... also have to find out why the interior light don't work too.
Good to see you still here!
Marc
I took some electrical cleaner, sprayed on mine, worked it back and forth a couple times and took a small brush to it. I also made sure the wiper was making tight contact on the spring. It has worked fine since then.
yellow- leave on the dimmer- this is to turn on/off the dome light.
black and tan- short these together- either get the two spade connectors out of the connector and either cut/solder and tape them or make a short wire with two flat spade male connectors to put between the two wires and tape.
I took mine apart, cleaned it with contact cleaner real good, made sure the slider was making good contact on the spring and put it back together. It works ok now, probably not perfect but alot better than it was.
