73 Challenger circut 7 fuse blown...
Postby spitfire9137 » 22 Sep 2005 12:34
Ok for some reason I blew the number 7 fuse in my car everyday. The manual says that it is for Heater, AC, and blower motor. I dont use the heat and my blower motor dont work, and I dont have ac. So my question is, is there something else also on this circut that would cause it to blow?
spitfire9137
Postby Mike l » 22 Sep 2005 13:51
Does the fuse blow as soon as you put it in?
Does it blow when you turn the key to start?
Mike l
Re: 73 Challenger circut 7 fuse blown...
Postby fbernard » 22 Sep 2005 14:15
spitfire9137 wrote:Ok for some reason I blew the number 7 fuse in my car everyday. The manual says that it is for Heater, AC, and blower motor. I dont use the heat and my blower motor dont work, and I dont have ac. So my question is, is there something else also on this circut that would cause it to blow?
Could also be the rear defrost fan, I believe it's on the same circuit/fuse. Heater and Vent use the same fan, so if you don't have AC, it should be simple to sort out. You must have a wire that's in short-circuit somewhere. Look at the wires goind trough the firewall, around the engine (especially between firewall and engine), and take a look at wires in the trunk too.
You don't have A/C, but maybe the wiring harness in your car has provisions for it, so check for any unused wires that may have fried on the manifolds...
fbernard
