Low Fuel Light On
12 Mar 2005 6:03
by Charlie Backes
What is the proper operation of the Special Edition low fuel light in the overhead console? I have 3/4 tank of gas and the light is on always. I replaced the relay with another one but it still stays lit. Fuel guage works OK. Where do we get a replacement relay for these?
Charlie
12 Mar 2005 15:50
by 71_DEPUTY
best to my knowledge it comes on about 1/4 tank!!!!
no replacement low fuel relays- just have to find one that works!!!
it is a special one- it has a built in voltage limiter for it to work properly- you need 12 volts into it, good ground to the case- usually there is a black wire to ground-, dark blue wire from the tank goes to the gauge and another dark blue wire to the relay and the output to the light.
make sure the ground is there!!!!
26 Mar 2005 4:11
by Charlie Backes
71 Deputy,
Thanks, you were exactly correct. I had to disconnect the voltage limiter and connect the second wire from the relay. The relay has a built in limiter and controls the gage and light. Works fine now.
I am working on an all electronic redesign of this relay so if anyone needs a replacement.........
Charlie
26 Mar 2005 21:05
by 71_DEPUTY
your welcome!!!!!!!!!!!
p.s- if ya get a replacement/ schematic diagram for one- let me know- never seen one but like to see how it works!!!!!!
27 Mar 2005 5:25
by spitfire9137
Hey charlie could you take of the consol. I've never seen one and would like to see one. Thanks.
13 Nov 2006 22:17
by rockanimal
71 deputy! You seem to know this subject. Where is the low fuel relay located in the car? Behind the dash?
Robert
14 Nov 2006 1:00
by 71_DEPUTY
yep- look for the dark blue wire from the harness taht goes to the back of the dash- but with the low fuel relay it goes to the relay only.
here is a pic of one- not 100% sure this is a E body one-could be a c body- but gives ya a idea of what it looks like!!!
20 Nov 2006 20:53
by rockanimal
Thanks Deputy! I got it all figured out and I think it works now. - Robert
22 Nov 2006 0:49
by 71_DEPUTY
your welcome!!!
