I have a rear defrost,but no switch on the dash,were they fitted beside the dimmer? dunno if it works yet,but I need it just now!
Fuel gauge and clock don't work,temp gauge works (most of the time) From what I've read,its probably either the sender unit,or the voltage regulator. I'll check these out tomorrow.
 by Kowalski_72 » 20 Dec 2004 2:11
 I'm not sure if my setup is original either,as I've seen the defogger motor mounted under the shelf,wheras mine is on the floor.... dunno!
 The good side of it, is that nobody (hopefully!) has been messing around there and doing a lot of harm...
