by Tooch » 13 Nov 2004 23:42
i hope this doesnt sound dumb,but,if you have 2 wires going to the dome lamp and the red is hot shouldnt the yellow be ground? the door switches have 2 wires, yellow also and the switch interupts the circuit when the door is closed turning the lamp off...right? well then why do i have 12.4 volts in the yellow wires when i test them and 12.4 volts in the red when tested and the lamp wont lite...but wait,it gets better.both wires on both sides were taped apart and tucked behind the kick panels.ok so i go to penstar and get the switches but before i install i check the circuits and have hots all over,probably why the tapejob, oh ,another thing i sit here for an hour studying the 70 fac/man and for my life i cant see where dodge says body ground or hot,anyway is the door switch circuit supposed to be a ground interupt,cause then all i got to do is isolate the the cicuit feed yellow,making it a ground system. thanks,and rub your eyes now,they probably hurt...TOOCH
