dome lite-door pin switches??
13 Nov 2004 23:42by Tooch
				i hope this doesnt sound dumb,but,if you have 2 wires going to the dome lamp and the red is hot shouldnt the yellow be ground? the door switches have 2 wires, yellow also and the switch interupts the circuit when the door is closed turning the lamp off...right? well then why do i have 12.4 volts in the yellow wires when i test them and 12.4 volts in the red when tested and the lamp wont lite...but wait,it gets better.both wires on both sides were taped apart and tucked behind the kick panels.ok so i go to penstar and get the switches but before i install i check the circuits and have hots all over,probably why the tapejob, oh ,another thing i sit here for an hour studying the 70 fac/man and for my life i cant see where dodge says body ground or hot,anyway is the door switch circuit supposed to be a ground interupt,cause then all i got to do is isolate the the cicuit feed yellow,making it a ground system. thanks,and rub your eyes now,they probably hurt...TOOCH
13 Nov 2004 23:54by Tooch
				and another thing! its the paddle switch dome lite in an rt/se o/h console. sorry....TOOCH
14 Nov 2004 0:57by 71_DEPUTY
				THE RED IS ACUTALLY A PINK HOT WIRE THAT gets it's power from the same source as the brake lights.
The yellow is the wire that goes to the pin switches in the doors. when the door opens, it grounds out the yellow wire turning on the dome light.
there could be 2 wires that go to the pin switches- yellow for the dome, yellow with a black tracer- for the "key in the buzzer and/or timed light for the ing.switch option.
my best guess is that the door pin switch is bad. Take the yellow wire and ground it to the body and the dome light should come on!!!
John Mac
19 Dec 2004 22:09by Kowalski_72
				This may sound like a dumb question (I've only had mine a day) but can you switch the dome light on without opening the door?
19 Dec 2004 23:12by dave-r
				Yes! You turn the dash instrument panel dimmer knob all the way to one side (same as on all modern Mopars/Jeeps). That is what you do on the rallye dash anyhow. I have never operated a standard dash.
20 Dec 2004 2:01by Kowalski_72
				I was just about to try it,but then realised its 2 am and about minus 20 outside..... I'll try it tomorrow!
22 Dec 2004 0:08by Kowalski_72
				Checked out my dome lamp today,I'm gettng a live feed to the lamp,but no earths,anywhere.The connector is in the drivers side trunk, pink live and yellow earth,you can also find a connector at the drivers side kick panel.Moe investigation tomorrow!
Right enough about the dimmer switch,Dave,but still doesn't work!!!
22 Dec 2004 8:46by dave-r
				Check out the electrical section on here for a circuit diagram.
Good luck hunting for those missing electrons. They must be hiding somewhere.
