by TimZappaEckert » 05 May 2005 22:03
Hey folks, very new to this message board. I was going to start a new thread, but this one seemed very appropriate. Hope I am not guilty of high jacking the thread...
Just bought a NOS turn signal switch for my 1972 Cuda (OH, sorry, forgot where I was, for my 72 Challenger.) Fredericks Dodge has a nice ebay store with NOS E-body turn signals switches available. (This info only applies to non-TILT steering columns.) This store offers two different parts:
Part A: For 1971, 1972, 1974
The picture shows two wiring harnesses (connectors) leading from the switch, a small one with 3 wires, and a larger one with eight wires. The larger connector has the same colors (if I can read the picture good enough) as my 72: white, brown, dark green, red, pink, tan, light green, black with tracer.) However, my 72 does not have the smaller 3 wire connector.
Part B: For 1970 1973
The picture shows only one wiring harnesse (connectors) leading from the switch, a large one with nn?? wires. This large connector seems to have a completely DIFFERENT wire color scheme, IF I am seeing the photo correctly.
Q1) Does anyone know why the 70 and 73 would be different from the 71 72 74? In other words, why switch from the 72 design to the 73 design just to switch back in 74?
Q2) Does anyone know what the smaller connector might be for as described above on the 71 72 74 NOS part?
Q3) Is it true that 70 73 has odd (odd meaning just different from 72) color codes on the turn signals harness? (Or is their photo just misleading on the colors?)
On my 72, this is what my colors do:
white, power supply when brakes on
brown, to right rear turn signal
dark green, to left rear turn signal
red, power supply from turn signal flasher
pink, power supply from hazard flasher
tan, right front turn signal
light green, left front turn signal
black with tracer, supplys ground when press horn
Thanks, Tim
