Dave, I hope this problem is similar to Caledon's.
I just got my car back two weeks ago with rebuilt 318 and 4-speed. It now has a new ministarter and new positive and negative cables. Ignition is the Mopar electronic ignition which I put in a few years ago.
The car ran great every day for a week and started immediately (the new starter is far superior to the original).
The car sat for a week. This weekend I decided to add a small connector to the positive side post on the battery; this would provide a better connection for the electric fan (I just used an alligator clip before). I added the connector (it clamps in place with the terminal bolt) and tried to start the car. Nothing.
I have power to the lights but nothing is getting to the starter (apparently) - it is not making any noise. I checked the battery two ways - my voltmeter guage reads at 10 and drops when turning the iginition. I used a multimeter too and it reads 12.46 - that makes me think the battery is OK. I tried to start with my portable booster anyway and nothing - the starter still does not crank. At this point, I do not know about power to the coil.
Note: I am not sure if I could hear the starter solenoid activating. I checked this morning and I do not hear it.
The only other things I did when adding that battery clamp are these:
I took out the battery and cleaned it, placing it on the garage floor for a few minutes.
I disconnected a green wire running from the starter relay to the firewall - I am thinking this may go to the transmission. I reconnected the wire after running it through a cable tie - it has a bullet type connector. I checked it twice and it seems to be properly connected.
The starter relay is brand new and all connections look good - also clean.
I would appreciate any ideas - meanwhile I will look at the wiring diagram.
Thanks
Duane
