OK, I've installed and plumbed the winshield washer reservoir and squirters on my '74, but I can't find the wire for the power to the electric pump.  This car was once a strict 1/4-miler, so everything was stripped out for weight savings.  My guess is the power wire was cut off someplace, but I can't see a "loose end" anywhere in the engine compartment.  I've looked under the dash and found lots of empty sockets, etc.  Since I don't have a wiring diagram (schematic) for this except for a '70 Barracuda, I can't figure out which wire from the back of the wiper switch goes to the washer pump, nor where I might expect to find the cut-off other end.  Anybody got any thoughts on where I should look for the cut-off wire (drivers side, passenger side, near a bundle that connects to the radio, that sort of thing)?
Thanks.
		 by Doug444UT » 01 Apr 2004 18:08
