I have got the alternator bracket kit by now. I thought it would be a simple bolt-in, but for some unknown reason it wasn´t. My usual bad luck I guess.
My crank pulley has 4 grooves and the water pump pulley has 2 grooves.
The steering pump belt lines up fairly well with #2 water pump groove and the #3 crank groove. (Numbers counted from front of car). That leaves the #1 water pump groove and the #2 crank groove to the alternator belt. My problem is that the kit demands the alternator belt to use the same grooves as the steering pump already uses.
I am 99,9% sure that I have bought the correct kit. The kit is made for a 987 water pump housing and my engine has a 987 housing.
(My car was originally a 318 car but the engine has been replaced with a 383. One idea that has struck me is that it isn´t unlikely that the power steering pump is from the 318 days. Does it fit my engine?)
Any suggestions or close-ups appreciated.
