Trans temp gauge install
Hey! I've just been busy installing a trans temp autometer gauge. The temp sender is placed in the side of the deep trans pan; no problems.
But at the gauge side; installed everything where it supposed to be so I would think there's no problem. But as soon as I put the ignition on, the pointer goes fully to the right side. Disconnected the wire from the gauge to the ignition and it stays left (=cold side) but as soon as that wire contacts the ignition wire it goes 'hot'.
The wire leads together with the +wire of the light to the ignition. While the light works normal, the gauge does not. Any suggestions?
Was thinking myself that the sender in the oil pan, which should be selfgrounding, doesn't give good ground as I used 'plumberstape' around the threat. But if I connects a wire from the header, pan, whatever, to the outside of the sender it doesn't help either... Am I missing something here beside electrical knowlegde?
